Looking to upgrade my mobo for Overclocking
Hey everyone! I'm looking into upgrading my motherboard, the reason i'm doing this is because my motherboard apparently isn't very good for overclocking. What i really want to know is what should I be looking for, I've heard VRM heatsinks and power phases but i'm not really sure what all these do (besides the heatsinks of course) I guess I just want to know what I should be looking for myself so that I can make informed decisions in the future.
I currently have an MSI 970A-G43, I was looking into getting heatsinks for that to help dissipate the heat, but i'm not sure if it would be a good idea?
Which cpu are you using ?
I'm currently using an AMD-FX 6350, but i'm looking less for recommendations and more for information I should know when looking for a good mobo.I would really like to understand things like the Phases and whatnot, what the VRM chip does, why it gets so hot ect. :)
its a bit hard for me to explain, because english is not my native language.
But lets start with  a powerphase, a powerphase is basicly a sort of wire over which the current is transported from the chokes to the cpu (and other parts on the board). you can basicly say more phases is better, because more phases, means less current over each phase. less current means less heat, and less loss. The VRM  (voltage regulation module) does basicly messuring all the incomming and outgoing voltages and current, and try to keep this flat and stable as possible. digital vrm´s are more precisely then older analog vrm´s. if something gets unstable, then the vrm tries to correct this. This all works to gether with the northbride chip, this is the toutchable part for the human´s. The Northbridge chip rules basicly everything the humanbeen is setting to it in the bios (overclock) The Northbridge chip is basicly the brain of all it.
offcourse this is not the whole story its goes much deeper, but since english is not my native language its a bit hard for me to get deeper into this, finding the right words.
But there are people arround here who can explain it better to you.
