Looking to upgrade my GPU, help!
Hello i have a amd fx 8120 (3.1ghz) and a geforce 660sc 8gb ram and my motherboard is a 970a-d3. i am looking to upgrade to a better gpu and was wondering if anybody knew a good one that would work well with my build; it dosent matter if its a nvidia or amd. my price rage is around 250 max i can go is 280. i play games like modded skyrim and all the fallouts along with bf3 and counterstrike GO . thanks for any info you might have!
I personaly would wait for AMD to unveil their new generation of gpus. The prices will drop significantly after this event.
Damn you beat me too it but yes patience is key here if you don't want to be paying throught the nose.
But in saying this, I don't see why you couldn't just save up for the GPU you want.
Also how big is your monitor, crt or tft also what resolution do you currently use?
Thanks.:)
Me three. 660 is just fine for now. The 700 series cards are just slightly twecked Kepler cards like the 600 series. My 760 is just a revamped 660 OEM card. The 7000 amd card have been out forever and are dew for a refresh starting in November I think. I would really really wait.
Wait it out. Rumors of next gen amd AND nvidia gpus are flyig around. the 660 should hold you off for now.
i don't think thats really enough of a budget for a decent upgrade, atleast price/performance-increase wise
another 660 for sli perhaps
Agreed. 660 should be enough to tide you over for now. If not, pick up a used 7950 for like $170~$180. Then, sell off your two GPUs (660 and 7950) once the new gen arrives.
I have the gtx 760 from evga and I just spanks everything around but it is also the card to replace the card you have. The 690 is a great card but for that price you can also go out and get a titan
I would recommend a Msi Radeon 7950 Twinfrozer.
This topic needs to be in the GPU section, please post in the right section next time.
Grtz Angel ☺
I would wait for the new Amd card's 660 is fine for now.
For a heavely modded skyrim I would recommend something like a AMD 7950, the 3gb of RAM will really come in handy but this is  if you can't wait. I would also wait for the new generation to launch.
