Looking to upgrade my case
I currently have a corsair 200r which is a good budget case, but I want a case that has better air flow and can fit a dual radiator in push in push pull with 4 fans. Also please don't recomend the define r4 beacause it will not fit a dual rad in push pull. People always seem to recomend that case even though it has very little clearence above the motherboard.
how much are you looking to spend
the CM 690 II is a good mid tower, can support dual 140 rads in the top and bottom
the phantom 810 and 630 are very good acoustically and thermally
I would like to keep it under $150.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160 is good for that price range
Looks like an awesome standard fan package in the HAF...looking to get one aroung the same price range myself.
