I recently moved back to the Altamonte Springs/Orlando Central Florida area , and receive a hand me down Dell Studio 540s. Out of which i’de like to pull the guts and put them into a full tower
It almost looks like some kind of EATX form factor but it might be different. You could end up having to drill and tap for some of the stand offs. Also looks like it has a removable I/O shield. The PSU doesnt look standard but you might consider swapping that out anyway.
Should be Micro-ATX something weird.
Its short like mATX but wider.
It’s too wide for that. You will need a E-ATX or even SSI-EEB capable case for this board.
nothing a cardboard box and some ductape can’t fix.
Got yourself a full tower right there.
Fully custom, works with every motherboard size.
The square shape and screw hole locations looks like a full microATX to me. Most boards marketed as microATX in recent years have been smaller than the 9.6" x 9.6" microATX spec. You could always check it with a measuring tape.
