Looking For The BEST Power Supply
DO NOT TALK ABOUT SEASONIC! They are crap and i will NOT buy one, I have read up on them for several hours and i was VERY disappointed.
Now, On to the main topic, I am looking for REALLY Good Brands, And i am looking for a 750W PSU for around 100 - 175$ Max, Please list Brands, And Specific Models and if you don't mind, Links as well, Thank you in advance !!!
Brands are the least important consideration. Power supplies are made by a manufacturer and then they get rebranded. Guess what? Most power supplies that are worth considering are made by Seasonic. including Corsair, XFX... you get the idea. And yes, Seasonic are widely regarded as the best.
I'll try to find you something, but it is hard work finding something not touched by them 0.0
Here ya go. If you can find any of these:
http://www.super-flower.com.tw/products_list.php?class=2&sn=1&page=1&lang=en
They are pretty awesome. I have had trouble finding them on any E-retailers. Hopefully, you will have better luck.
Here's the "where to buy" page:
http://www.super-flower.com.tw/location.php?lang=en
I would love to get one since it is not a Seasonic or a Rebrand of Seasonic but they are not selling in the US, So i am SOL on this one.
http://community.newegg.com/eggxpert/computer_hardware/f/135081/t/45344.aspx?pi5025=1
Get something from tier one.
That's a shame. I actually learnt about them from American forum members. Figured there would be some availability in the US.
Get a Seasonic :D
They aren't bad. I am running a Corsair AX760 right now, made by Seasonic. Best unit I ever had. My mum's PC has a cheap XFX 450, again, no problems. There's a couple of reviews to give you some faith.
Join us, come to the dark side. I mean, everyoooone else is recommending them, so why not?
ERG FINE!!! Give me three links for 750W BEst ones you can find and i will get one of them! GRR!
I was thinking about grabbing this one here ---> http://www.newegg.com/Product/Product.aspx?Item=N82E16817438017
I'll turn up some Seasonics and whatever else I can find. Nice to have the option, doooood
This one is not Seasonic. It's made by Channel Well Technology, which happens to be a pretty good choice of OEM. Not as good as SEASONIC THO!
http://pcpartpicker.com/part/corsair-power-supply-hx750
It's a "step down" from the AX, but it is really solid! Reportedly, better than the RM series that replaced it.
These are all Seasonic OEMs. Single rail. Definitely worth considering, but I think you'll be more than happy with the HX!
http://pcpartpicker.com/part/xfx-power-supply-p1750bbefx
http://pcpartpicker.com/part/corsair-power-supply-ax760
http://pcpartpicker.com/part/seasonic-power-supply-ss760xp2
http://pcpartpicker.com/part/seasonic-power-supply-x850
This looks pretty awesome, it's at the top end of your budget:
http://pcpartpicker.com/part/fractal-design-power-supply-fdpsunt3b800w
The list is not exhausted. Of course, there are some Rosewill PSUs that are worth considering, among others. But I know the listed units reasonably well. Low ripple, solid Japanese caps.
Grab me some SeaSonics... I will try it ONCE but if it fails, No more... Grab me the BEST three SeaSonics you can find.
I think you would be happy with the HX, to be honest. Really affordable and very good.
Most Seasonic units on the list Mo_Elguhiem provided are worth considering. The X series is held in really high-regard. I happen to like my AX unit. Feel free to choose. I largely agree with that list. You see anything in tier one that you like, go for it. Seasonic or not Seasonic.
How bout one of these
http://www.ncix.com/detail/evga-supernova-750-g2-80-f0-94405.htm
I would buy a potato with 2 copper wires if it was Gold and had a 10 year warranty.
Here is a PCper review
 http://www.pcper.com/reviews/Cases-and-Cooling/EVGA-SuperNOVA-750G2-and-850G2-Gold-Power-Supply-Review
I have come across that first link you posted several times, i think it's a sign, im going for it possibly. Going to look around some more.
Be sure you look for the G2  the original G is not as good.
I did, I have had such bad luck with my build for the past year and a half, i just want it to work...
TEN years?! I think mine is 5 or 7 at most!
