I'm looking to replace my AMD FX 6300 for something from intel. My budget is $350, any suggestions?
I just purchased an i7 4790K and it is overclocked to 4.7GHz. I'm happy with it.
He needs a motherboard to go with it as well since hes on AMD.
@Macaque I would suggest getting an i5 4460 and a h97 motherboard which should fit your budget if you are in America.
Again, if you're in the States, you might be able to squeeze in an i5-4690K and a Z97 motherboard.
i5 4690K - $230 http://www.newegg.com/Product/Product.aspx?Item=N82E16819117372
ASRock Fatal1ty Z97 Killer - $110 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157501
GIGABYTE GA-Z97-HD3 (rev. 2.0) - $103 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128715
ASUS Z97-E/USB3.1 - $115 http://www.newegg.com/Product/Product.aspx?Item=N82E16813132512
He didn't state that. XD
You can overclock this
Sorry, forgot to mention I'm in the US. Anyways, appreciate the suggestions.
