Link to build: http://pcpartpicker.com/p/1tgBP Budget doesn't really matter but cheaper is always better. The 3 monitors there are there to hold the price at roughly what it would be for the monitor I'm really getting.(http://goo.gl/qfSJc9) Cost $24/$25 dollars more, I know, Just a place holder. My main use would be gaming at stupid high settings/resolution. I will likely get into recording and editing gameplay videos. I'll have it bitcoin mining while it's not gaming.Just wondering what advice you would have for me and this set-up.
I would definitely look into much faster RAM. That motherboard can handle 1866Mhz with any overclocking, so I would definitely get RAM that runs at 1866. Higher if you are comfortable with tweaking in the bios.
I honestly doubt with these parts that you have listed you would come anywhere close to 1000 watts of power let alone need a 1500 watt power supply. I would look into anwhere between 750-1000 watts. Anything more would just be a waste. Its not like you're going to run 4 Titans in SLI.
I personally would also suggest getting Windows 8 rather than 7 seeing as how the 8.1 update is only a few months away.
I noticed you dont have a case listed but I would recommend the Corsair Air 540. Amazing air cooling and watercooling possibilities with that case.
Other than that, looks like an impressive build.
Should switch to AMD gpus if you plan to bitcoin mine.
