Looking for some quiet fans to replace stock H100i fans
Hey guys do you have any suggestions on some quiet fans for my H100i? I'm getting tired of hearing the stock ones all the time. Im looking for some black or white ones so it will match my build.
Personally I'm a fan of the cougar vortex fans.
I actually just replace the fans on my h105 (those suckers are loud!) with these - http://www.newegg.com/Product/Product.aspx?Item=N82E16835214059
They are way quieter and have a hardware switch to limit the peak rpm's if you want to make them even more quiet. I use mine on the middle setting and they still keep my cpu under 40 degrees C no problem after 3 hours of playing gta V.
Of course the best option is still - http://www.newegg.com/Product/Product.aspx?Item=9SIA6502UE5885 but sadley the color scheme doesnt work. If money isnt an issue I would get the - http://www.newegg.com/Product/Product.aspx?Item=1YF-000T-00019
Lol Newegg has the Noctua stuff listed as First from Asia. Noctua are from Austria.
Does that Enermax fan come with two or is it just one?
you should look at the cooler master blademaster http://us.coolermaster.com/product/Detail/cooling/blade-master/blade-master-120.html i got them on my h100i not bad at all
It comes with one, but honestly they are well worth the price.
Noctua NF-F12´s it wont get much quieter then those i guess.
