Hey guys, I am looking to replace the 120mm fans on my antec 920 liquid cooler. The stock fans work well put they are extremely loud under higher loads. I want to get pwm fans that have good static pressure for rad usage. Price really isnt an issue but i do need 2 for push/pull. What are your suggestions?
Oh btw, my case color scheme is red/black if that helps. It doesn't really matter too much to me though.
Why don't you get some corsair air series sp-120s? Those fans are great and have a ton of static pressure and I could even argue that you wouldn't need to use a push/pull config. If color is an issue then you could just swap out the color ring to the red one.
