Looking for Mid-range cards
So I've been out of the whole computer tech loop for a while now. What are the value mid range cards floating about nowadays? I think its time for an upgrade and just want to weigh out my options
what is your budget?
Depends on your budget and what you consider "mid-range". You can actually get a pretty high-end card like the R9 290 for as low as 250$-300$.
