Looking for input on a suggested build
I am looking to make a gaming rig, I want to be able to run games like Arma III on at least mid settings without lag. My wish is basically to game as smoothly as possible. $800 is probably the cap, but I could maybe go slightly higher if the upgrade would warrant it.
I posted this request elsewhere and received this suggested build: http://pcpartpicker.com/p/1MNuS
I would like to know if this is a good setup, and if you have anything better, feel free to edit it as you see fit.
Also, I haven't actually built a computer before, I've been researching and It doesn't seem like it will be too much of an issue, but let me know if there is anything I MUST know prior. Thanks a whole bunch guys, I appreciate any help.
The build is pretty solid, but I made some improvements anyway. http://pcpartpicker.com/user/Sheepyy_/saved/2Ask
Okay to justify all of my changes:
Hyper 212 EVO cools much better, one of the best price-performance air coolers out there.
ASUS motherboard cause the Asrock Extreme series don't overclock nearly as well for a similar price.
RAM; Not a necessary change, but I don't like 1333MHz.. it just bugs me for some reason. Mushkin make really good products.
Case; Tempest has great air flow, best you can get for the price really. NZXT also generally make better products, build quality wise (though I've only used 3 bitfenix cases before in friends builds, they seemed very flimsy) and I needed to cut down somewhere to stay within budget.
PSU: Although I like the CX-series power supplies, with them being really cheap for the power you get, you get what you pay for with them. OCZ make really good PSUs since buying PC Power and Cooling (I think they bought them anyway), with the ZT series being their best. I went for 750w so you can crossfire or upgrade in the future, whilst still having more than enough headroom to overclock.
EDIT: If you can stretch your budget, go for a 7970, as their prices are dropping lower than ever.
All, so far seem like solid choices, a pretty good rig for less than $800.
Do you already have an Operating System? Windows 7? 8? Cause if not, that's about another $100
Some must know knowledge (if you don't already know):
ALWAYS download the drivers for your motherboard and video card before you start building, that way, you have the most up to date drivers and you're ready to start installing.
NEVER touch the gold pins on AMD CPUs or if you're going with Intel, on the motherboard.
When installing a CPU DO NOT apply pressure when mounting it to the socket. The lever will do that for you.
When REMOVING AN AMD CPU, twist the heatsink a little first to loosen the thermal paste for easier removal, otherwise the CPU may come off with the heatsink and either damage the CPU or socket.
Getting your own thermal paste usually gives you better temps under load. Try Arctic MX-4, or if you have an all copper base heatsink I highly recommend Coollaboratory liquid pro or liquid ultra.
WHEN MOUNTING LARGE HEATSINKS, I recommend mounting it BEFORE installing the motherboard inside the case, that way it's easier to install overall without the case getting in the way.
I recommend MAKING AN OS PARTITION on your hard drive; that way, if your OS gets corrupted or gets infected by a virus you can re-install you OS without losing your games, pictures, music etc...About 150GB should suffice. A partition is basically dividing your hard drive up into another portion....Google and YouTube are your friends.
