Looking for help with TrueNasScale With a ConnectX-3 nic
Hey looking for some help troubolshhoting some odd behavior, that I’m getting with my TrueNas sacle box, recently I’ve been trying to install a connectx-3 duel port sfp card in to said box, however soon as I install the nic and boot all the network interfaces just to stop working sort of see screenshot :arrow_down_small: , even though the OS and routers arp table say all the old connections should have connectivaty and an ip from the dhcp server. I still can’t reach the webGUI or ping them ect.
I know its and old card and EOL but it should still be supported for at lest a while (it was a freebee) i think it coame out a windows server if that matters at all
relative parts output of ip addr.
Edit
so after running dmsg | grep eth looking at the logs again aparently the last device has been renamed form usb0? so im even more confused now
** Edit End**
soon as i unintall/remove the nic it all goes back to working as before.
I’ve looked though the boot log i cant see anything out of place relativly new to the boot log,
the nic seems to show up with ip addr so i dont think it should be a driver issue might be wrong though :joy: .
Just looking for a bit of advice or more indepth help on where i should start looking as I’ve been trying to get this to work for awhile now but with no luck :frowning: and getting to the end of my wits.
Thank you in advance!
Hi
Did you check the firewall? If the interfaces get renamed your rules might not point to the correct interfaces anymore
@gysi
I dont think thats this the issue as the interface they connect to is fully open and ips are assinged useing the dhcp server and keep happaning regarless of reboots.
I know it not hardware related as I’ve tested the card in both a windows 10 system and a freeBSD PFsence router and it works widows required the driver.
Though there is something odd i cant find the mellanox nic as a pcie device at all in the cli useing lspci
I don’t have not managed to install the driver on TrueNas Scale though since as i can’t connet to the outoutside on the box to down load it. but im not even sure if it’s required sure it would not be causeing the issue im trying to slove. :thinking:
10.0.1.1/8 and 10.0.0.6/24 are overlapping … check your netmasks
I would install all drivers unless TrueNasScale has already done that for you. I think I know what is wrong; I would check my DHCP server some of the IP4 addresses don’t look quite right to me.
:open_mouth: How did I not notice that! :facepalm: and how the heck did that even work in the first place :confused:…
Ip and now both /8 updateing that part of the config fixes the inital netowrking isseue that’s no suprise :joy: but I’d love to know how that even worked in the first place as it should have been behaving real funky in the first place not just when i added the seconed nic.
I’ll start getting the driver installed for the seconed nic since thats the next step :slight_smile:
Thanks,
Every ones help fixing my daft mistake ill post an update once thats done
I did think the IP address 10.255.255.255 did look a little funny.
@Shadowbane
That’s the brodcast ip the actual ip’s were 10.0.1.1/8 and 10.0.0.6/24 which seems to have been the root of the networking issue.
Though hears a wee tid bit about ips and networking i do know :joy: .
X.X.X.255/24 is used for brodcasting.
X.X.X.0/24 is the networks identifier.
After trying to install the driver for the nic for the last lil bit
theres no supporeted version do ture nas scale which i expected, since the os if a fork of debain i grabed the lateser version witch was for debian 10.0 old I know but it is a very old card :joy: to see if i could bootstarp it a bit but the prebuilt driver wont install due to the os not matiching,
but all is not lost since the driver source code is also provided i might just have to make a few twecks and build it form that but thats my last resort.
but before i resort to the nuculer option i looked at the docs again where i found
so i dug though the drivers to see what was installed and i found
so it seem that theres a matching driver though i cant tell what version it is exsacly.
but iv done a bit more digging to lean a bit more about drivers and what not and found this blog post form redhat How to install a device driver on Linux which seems to point too.
If a driver is recognized by those commands but not by lscpi or dmesg , it means the driver is on the disk but not in the kernel. In this case, load the module with the modprobe command:
so it seem I need to get modprob installed after i add a repo that has it and hope i don’t brick the install :joy:
@Tiny_Goliath OPPs, I got the broadcast address mixed with the subnet; I see that now.
Turns out I’ve done another dumb along side my ip config
turns out the bios was also set wrong and had the slot disabled… :face_exhaling:
Seem this was the resson that the card in pci4 was not showing up in the first place was due to me not enabling that slot in the bios though still baffled why installing the nicin a disabled slot caused the other networking issue to crop up due to the overlaping ips.
but with all that sorted the os now see the the nic! :partying_face:
Thank you everyone for your help fixing the issue and letting my rubber duck a bit, :joy: while we got my issue sorted
