I plan on build a new rig with 1440p monitors but im not sure what parts can make the most of that resolution. I dont really have a budget for this but I want to keep it Amd for cpu and gpu. any recommends for fans, gpu, cooling, mobo is extremely helpful and thank you.
1440p huh? Here's a build that should be able to do pretty well. Tower hardware only.
http://pcpartpicker.com/p/TYy7sY
If you need it cheaper, you could do away with the SSD, and a cheaper CPU cooler.
Looks good to me. Should be able to max quite a few games at 1440p.
Ya looks good.
thank you very much
