The original graphics card that went into my first PC build has died on me. =( I had a Radeon HD 6870 graphics card for 2 years now, it did a fine job for the games and programs that i use frequently. It decided it had had enough, and choked out on me.
A good friend of mine was kind enough to loan me a GeForce 9800 GTX that he had in his closet. It isn't as good as my card, but it will do until I get a replacement.
I have a $200 budget, give or take a few bucks. I want a decent graphics card, and with all of the holiday sales coming up, i'm actually glad that my card died before, and not after the new year.
Specs:
AMD FX 8320 8-core
GeForce 9800 GTX =(
8gb RAM
Win7 x64
2 1080p Monitors DVI
1tb hdd and 500gb hdd
500 psu - Needs upgraded too?
EDIT: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard
Let me know if i need to give more info.
I really appreciate the help. I know a fair amount about computers, but i always worry about compatibility.
There's always the option to wait for Black Friday or Cyber Monday.
If you're willing to stretch your budget a bit, I'd say that an R9 290 for $250 is a great buy.
Otherwise, I'd look at R9 270s for around ~$140. With the 270 and 290 being so low, I don't think the 270x/280/285/280x are really worth considering anymore.
If you take Morgoth's suggestion of the R9 270, I've got a pair of XFX R9 270 DDs that I would gladly hand over for $160. That's assuming you can do Crossfire.
I just added all of my parts to PCpartpicker... I came just over 500w.... i may need to upgrade it, afterall. Might be able to get a trade with someone... i have another 450 as well.
