hi all, first timer here
i've been watching some of the Logan's videos on youtube, although the Corsair Obsidian 450D is nice, but it is too big for me, but i must say the front panel is pretty nice, since its really easy to take out and clean
since i'm looking for smaller case, something of a micro atx size, that is easy to clean, without having to move the whole case every once in a while.........
suggestions? thanks!
Consider the new Air 240.
If you appreciate the Corsair style of chassis, you'll probably like Fractal cases too. Very clean look.
I was really looking forward to the Air 240 but after some searching I found the Fractal Design Node 804 that has a similar set up. Link
Only problem is that it doesn't offer the two positions that the Air 240 has.
http://pcpartpicker.com/part/fractal-design-case-fdcaarcminir2blw I've got the Atx version and I couldn't be more impressed. I literally have a cup of dust stuck in the front dust cover (which I should clean since its so damn easy). Aside from the dust in the intakes there is not a single spec in the inside of the computer. The ascetics are clean and elegant. Very deserving of a spot in a classy office. The sound damping is pretty good. Nothing amazing but not bad.
