I want something relatively easy to build in, mid range and quiet. Does anybody recommend a case like this? I currently have some cheapo generic case that came with a dodgy power supply, so anything's an upgrade. Also, I don't plan on having any crazy water cooling set-up or anything like that, I've got an R9 270x and some mediocre AMD parts (stock cooler which I'm replacing soon anyway) as well as a few Noctua fans.
P.S I live in the UK so I dunno, export charges and stuff.
take a look at the fractal arm mini. i'm super impressed. it's got some size for a matx, but that's because there are nice drive cages in the front and fans all the way around, also cable management makes for a bit of room. i modded the foam on the egress fans in the "lid"... well i just cut it out, but it did ultra nice and looks awesome.
Arc Mini R2 is not just window mod for the arc. It has removable and rotatable bottom hard drive cage, better quality rubber grommets, front fan controller placement, 2xUSB3 ports at the front, instead of one USB3 and two USB2, and the window. And let's not forget the SSD brackets at the back of the mobo tray.
This is over a month old, but I in case you didn't buy anything yet, I'd recommend the Phanteks Enthoo Evolv. A little more so then the FT03. But I've seen deals for the FT03, since it's an old case.
