Looking for an affordable 4-way 4k output multiviewer
that has 4 the type c at the top on the left side it the 4th
you can alwasys download the manual and look at it if you need more info
i did download the manual for the 32MU59 only listed 2X HDMI and 1X DP as inputs
wow your right has the 4 way display option but it only has 3 inputs wtf
HDMI
Yes x2 (ver 2.0)
DisplayPort
Yes x1 (ver 1.2)
So that W one is the only option at 32"
Exactly see that’s why I’m worried it’s only software driven becausd they do have that as a software package.
Its not only software driven i would guess, as the 43" also lists “S/W Install CD
Yes (True Color Pro, On Screen Control, Dual Controller)” yet has it through the menus with no software isntalled “S/W Install CD Yes (OnScreen Control, Dual Controller)”
I coulnt see them no putting in on the OSD controlls
