Looking for Advice Home Lab Custom Build on AM5
Hello all,
Long-time lurker here, looking for some advice on the latest AMD offerings for home lab setups.
I’m currently using a Dell PowerEdge T430 running Windows Server 2019, which I got from work over six years ago. This machine has served me well, but I’m running out of storage and want to move to a more DIY setup for better hardware support. I’m also a bit wary of relying on the Dell eBay market for parts.
Current Dell T430 Configuration:
  • (2) Intel Xeon E5 2640 v3
  • 96GB DDR4 2133MHz
  • Quadro P4000 GPU
  • HBA with RAID 5 on 5 x 2TB WD Red SATA SSDs
  • 10GbE NIC
Services I’m Running:
  • SMB Shares
  • Hyper-V VMs:
    • Linux VM (Docker, Portainer, Heimdall, Redmine, NextCloud, PiHole)
    • Linux VM (Desktop Experience)
    • Windows XP
    • Windows 7
  • IIS:
    • Revit Servers 2022–2025
  • Plex: with GPU support using the Quadro P4000
I’m considering transitioning to an AM5 setup, running everything on a hypervisor from the start. Specifically, I’m thinking of using Proxmox as the hypervisor, migrating all my VHDX files from Hyper-V to Proxmox, and using a TrueNAS Scale instance through Proxmox to manage network shares. This setup would allow me to snapshot all my configurations, making future migrations easier.
Proposed Build:
  • Case: RackChoice 2U Micro ATX Compact Rackmount (2U case with 2x 5.25" bays, allowing for a full-size PSU) - $102.00
  • Fans: Noctua NF-A8 PWM (replacing existing case fans) - $25.90 for 2
  • Backplane 1: ICY DOCK 4 x 2.5" SATA MB604SPO-B (for compute and OS RAID) - $174.99
  • Backplane 2: ICY DOCK 8 x 2.5" SAS/SATA HDD/SSD Enclosure for 5.25" Bay (2x Mini-SAS HD) - $264.99
  • Cooling Fans: Noctua NF-A4x20 FLX (for backplane cooling) - $44.85 for 3
  • PSU: FSP Twins Pro ATX PS2 500W (redundant power supply) - $439.00
  • HBA: LSI Broadcom SAS 9300-8i (RAID card for the backplane) - $69.00
  • Cables: 10Gtek 12G Mini SAS Cable (for RAID card to HBA) - $39.98 for 2
  • SSD: WD Red SA500 NAS SATA SSD (x4) - $1,239.96
  • Processor: AMD Epyc 4244P (6-core, 3.8/5.1 GHz) - $249.00
  • Motherboard: MSI D3051 (D3051GB2N-10G) with 1x PCIe 5x16, 1x PCIe 4x8 - $462.00
  • Cooler: Noctua NH-L9a-AM5 (low-profile cooler) - $44.95
  • Memory: Crucial 32GB DDR5-5200 ECC (64GB initial, 128GB max) - $216.00 for 2
Total: $3,372.62
I do a lot of 3D modeling and animation for the architectural and construction industry, so I need a setup that can handle large file transfers quickly. My home network is entirely 10GbE, and I want to ensure my storage and services can keep up with that speed.
I believe this build will be effective for the following reasons:
  • The processor’s core speed should easily handle VMs and file transfers, especially with M.2 cache from TrueNAS.
  • The two PCIe slots should be enough bandwidth to support both the GPU and the LSI card.
  • The integrated 10GbE NIC frees up a PCIe slot, which is ideal for adding a GPU and an HBA that can expand to 8 SAS/SATA SSDs.
  • The redundant PSU is a must-have, given that the only component I’ve had fail in my Dell setup was a redundant PSU.
However, please note that my knowledge in this area might be outdated, as I haven’t kept up with server hardware developments for a few years. I would greatly appreciate any feedback on my build or suggestions for improvements to better align with my use cases.
Thanks in advance!
@wlburks good first post, you outlined your parameters well
TrueNAS is best ran baremetal.
We still run Server 2022 as HyperVisors in prod until ProxMox can properly replace ESXI / Server 2022 Datacenter
Your Linux VM’s can easily be migrated to run on ProxMox, the IIS servers though will be interesting.
Will you be converting your current server to be a backup server?
this is a very well thought out build.
if virtualizing, use TrueNAS CORE. make sure to configure the nic as VIRTIO, or passthrough a NIC, as well as the HBA. (there are some small performance thoughts to keep in mind rather doing a passthrough NIC, or VIRTIO, both are good options though.)
memory will be your limiting factor. 64gb is boarder line.
you might be interested in doing some sort of vGPU or GPU passthrough if you really want to have a true virtual desktop. if so, this can be a major sidequest that can derail quickly. just be cautious here.
Thanks for the feedback. I was planning on doing a new Server 2022 on Proxmox to host the IIS services. Autodesk Revit Server requires windows server with IIS. The data on the 2019 server I can migrate when both servers are up.
I had thought about using the Dell as a back up but I largely use a 4 bay Synology to backup locally.
Yeah I was wondering on the memory because of what i read online about how TrueNAS functions. I should just do max ram based on the feedback.
I was thinking just now based on the initial comment that maybe I use the old Dell for the VDI server. I have friends that are nostalgic for an early 2000 LAN party so building that on the Dell once the migration is complete would be pretty low risk. I have 4 Quadro K4000 collecting dust and I should be able to slap three of them on the Dell.
I take your point though that a separate chassis would be better for multi GPU workloads. I really just want the one PCIe slot for the Plex transcoding card.
Consider replacing all of this with a 16TB NVMe SSD, e.g. Micron 9300 Pro. Faster, cheaper, significantly less complicated (=more reliable), future proof.
Oh snap interesting idea. I’m seeing used drives at that size around $1k and I would need three for a decent RAID so this would add a chunk of change but would be much much simpler from a parts and pieces standpoint. I’ll think it over some more to see what would change to try to support U.2 SSD.
From what I heard WD red nvmes are indeed durable but are not known to have the most advanced chips.
Another thing to consider is that enterprise drives require significantly stronger airflow to keep drives cool.
I don’t think the Noctua case fans cut it. I succeeded with enterprise level fans (80x25mm) with the resulting power draw and noise.
Yeah the plan was to have this in an under desk rack with the rest of the gear. I was able to wire in PWM Noctua fans into the Dell case so I could tolerate having it next to me. The temps on the WD drives in the Dell chassis are fine with Noctua. How much more demanding are the U.2 drives from a temp perspective?
With “normal” desktop airflow these drives are cooking at >50C when idling.
They require dedicated fan(s) and thoughtful airflow design.
Wow wlburks, this is a well-thought-out build plan! AM5 for a homelab is definitely an interesting choice. The Epyc 4244P seems like a solid option for VMs and file transfers. Maybe consider a Ryzen 7000 series CPU if you want more cores for futureproofing, but the 4244P looks good for your current needs.
