My Creative x-fi SB platinum no longer has proper driver support, the drivers just spontaneously break at random and I figured I should just replace it. I've heard the ASUS Xonars are good and cheap, so I want to ask some things about them. I would also like some 2.1 speaker reccomendations, and I'm using this entirely for listening to mp3s.
1) So is the Xonar DX @ 192 khz worth 50$ more than the Xonar DG @ 96khz? Is the quality significantly better on one?
2) I've read that the drivers for Xonars can be a hassle to install, so is there a surefire way to get it working? Or is it hit/miss? And do they have a built in EQ?
3) What are some good 2.1 speakers at 50-100$? All I want is good sound quality, no need for any fancy features.
if you want good quality in that price range, get some good 2.0 speakers. Much better audio quality much cleaner, cheap woofers kill the audio quality, trust me ;)
Honestly, I have to agree; for $100, there are not too many good 2.1 systems, though some decent 2.0 speakers can be had. Another option are the Creative GigaWorks T40 Series II; they are actually not bad for the size and price. As far as the soundcard goes, I am VERY happy with my Xonar Essence STX. Notable improvement over even the half-decent onboard audio of the ROG motherboards. As far as the DX vs DG goes, obviously the DX is going to be better, and given a choice, I would go for the higher quality soundcard.
Think about it this way: the soundcard is a DAC/Preamp. Whatever signal it is going to send to the speakers is going to be amplified. Send a noisy signal, you are going to get lower quality sound. Send a higher quality signal, and you have a cleaner source, meaning better sound, so the preamp is a very important stage. It is however, only as important as the quality of amp/speakers you use. Pick crappy speakers, and it wont matter how good your soundcard is.
Cliffs: Bite the bullet, and get the better quality components. Go for the Xonar DX, and something like the Creative T40 speakers.
I'm using the ASUS Xonar Essence STX, with a pair of studio monitors and Senheisser headphones. Just make sure the card you get has the outputs to match the speakers you get. That card probably isn't what you need, but I'm happy with it, so other in the same line may work well for you.
Not what your asking, but if you want quality, I'd start with a set of headphones and save up for a nice set of speakers. Get a mod mic and you can turn them into a quality headset if you need one.
