Looking to buy a new phone. Any advice would be appreciated as I haven't really had the need for a phone in a while and don't know really where to start looking for a new one. I want something that won't break into a million pieces if I drop it (NO GLASS SCREEN,) and a service provider with some good standing.
all phone screens are made of some form of glass, because plastic isn't durable enough. I would recommend starting the search with an Android device. Go take a look at Best Buy, but make sure you stop by the store for the service provider before buying the phone to make sure that they would be willing to insure the device. Get this assurance in writing. Then go buy a phone from Best Buy, because the initial charge is so much less expensive, and get it insured by your provider because their insurance is ALWAYS better. I'm with Verizon, and I find their service to be adequate, although their prices can be quite steep at times. If you decide to go with Verizon, I recommend looking at the LG G2 at Best Buy. Currently the price has dropped dramatically to only $49 with a new service plan.
Thanks, I will definitely give this a look. Appreciate it.
may i recommend the brand new Nexus 5? it is $349, but you own it out right. unlocked. you can take it over to T-Mobile (or where ever the phone supports) and get a plan for like $55. no contracts.
when you see phone for like 0.99-199, thats the fee up front, and ONY with a 2 year contract. you end up paying $80+/mo and eventually pay off the $600+ phone over 2 years.
the Nexus 5 is also top notch. GREAT specs. full 1080p screen. backed by google. unlocked, stock android (no bloated UI overlay like 99% of other phones)
idk, that's what i would do =)
If you want something cheap go buy the Nexus 5, like the guy above me said it has great specs. The other two phones that I would recommend would be the HTC One or Galaxy S4. It really just depends on personal taste and how much you are willing to spend.
I would highly recommend a Nokia Windows Phone. Very fast, comes with Office, and will NOT break when you drop it. I dropped it out of a moving car and i retrieved it. It had a small scratch and that was it.
Id say maybe sit back and wait a few months if you can. durable is the new "hot thing": in phones and all the companies are trying to get their new "unbreakable" phones out. if durability is really and issue maybe wait it out and see which one matches your needs. If you cant wait for one reason or another then Id suggest somthing like what Weston said. being stuck in a 2 year contract absolutely sucks.
