Looking for a low profile pci-e extension cable
I need to use a 1x slot which is covered by a graphics card, I bought a pci-e extension cable but the connector is too tall and I can’t seat the graphics card all the way in with the cable installed. Does any one know of a low profile cable of some kind that will fit under another card?
This is the kind of cable that I tried
I literally just made a post about this:
What you want is the XCSOURCE AC1291.
https://www.newegg.com/p/1W7-005X-00038?Description=90%20degree%20pcie%20cable&cm_re=90_degree_pcie_cable--9SIACJF7729688--Product
lowest profile one I can find
Yup, that’s the XCSOURCE AC1291. It’s got multiple names it goes under and you can find it cheaper on Aliexpress.
Thanks guys, I’ll check it out
