I'm looking for a good monitor to finally rid of the 24" 1080p TV through VGA I'm using right now, since I switched over to the 750ti I've seen an annoying flicker that I can mostly blame VGA's analog being interrupted by near by electronics. I'm now planning on switching over to DVI, but I figured I would do it right and get me a nice low latency monitor with good contrast levels, I'm having a hard time choosing however. I'd also like to move to a 21.5 inch monitor over my 24 inch TV because of the pixel density, less visible aliasing is a win for me.
I've found 2 monitors with similar spec sheets, one from ASUS and one from Acer, I'd typically jump on the ASUS one but the Acer model is honestly more as the ASUS one is mostly gloss it looks like, which is a fingerprint and dust magnet from the firey pits of hell. I also think the Acer one has a better contrast ratio judging by the specs, but monitors really aren't my strong point in PC hardware. I'm leaning more however toward the ASUS one because it meets a vesa standard mount if I want to get a monitor arm in the future, and the support I imagine is way better if this thing decides to go thermonuclear on me.
Which one should I choose, or is there any other possible recommendations in this price range?
Requirements: Low latency, IPS, 1920x1080 (or higher, but I doubt you'll get better for this price.) Good contrast ratio.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009484
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236205
[Edit]
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005363
This one however I can get for $120, much cheaper but the latency is higher, would the difference between 5ms and 14ms be significant? The contrast ratio is also 5,000,000:1 instead of 50,000,000:1 like the ASUS monitor.
