How can I tell if the MOBO will support proper GPU passthrough and Homelab?
Wondering about the Gigabyte Z690 UD
Thanks!
Thanks!
My understanding is all of them support passthrough but the thing you need to worry about is how the iommu groups are setup on the board
Did you mean 13700k or 10700k
103700k
That’s what I’m asking about. How can I know how the iommu groups are set and if they work with homelab?
The 103700 doesn’t exist only a 10700k or 13700k
A 10700k will be incomparable with a z690
Iommu groups are sometimes listed in motherboard manuals which you can download from the support section on the product page of the board
You can also check YouTube reviews, I think Wendell in particular usually goes over them
The manual doesn’t specify for this board.
Stay away from the scam company that is Gigabyte. See for example this thread (hilarity ensued) Gigabyte MW34SP0 Motherboard - #264 by Ardillon
