Logo fail detection?
I ordered a motherboard from china for reasons I do not need to go into. However it is a older series x470 board and at one point had the logo fail vulnerability. Is there a way to detect if it has been exploited? If it has, is it possible to patch it and removed the security issue after the fact?
I imagine a simple flash of bios would not rid it if it is indeed infected, however if not infected there is a bios rom for that exploit on the motherboard site.
@PhaseLockedLoop
The only way for you to say for certain is to use tools like chipsec or uefitool and do a full firmware dump
Here youll be doing static analysis… So using tools like IDA pro would be smart… You need a disassembler. There are some available for linux as well. It translates machine code (binary instructions) into assembly language, which is more readable for humans. You cant translate it to its compiled language as you have no reverse lex :rofl: but at least you have the asm
The next thing you do is you need dynamic analysis. Catching the exploit in action. Boot your system with debug logging to see what’s happening step-by-step as it loads. This helps spot if anything unusual is going on.
Really all in all if that seems more trouble than its worth then perhaps consider getting rid of the hardware since you clearly do not trust it
The thing is I am paranoid about everything. I mostly try to ignore it. Either way it is being sold as new in box.
You can always use tool like what below to fully wipe the BIOS and then install the BIOS with the patch. Just make sure the EEPROM programmer is compatible.
Example: Amazon.com: AiTrip EEPROM BIOS USB Programmer CH341A + SOIC8 Clip + 1.8V Adapter + SOIC8 Adapter for 24 25 Series Flash : Industrial & Scientific
