Logitech MK270 combo set -- which mouse does it have?
I’ve been a fan of the Logitech MK270 wireless set for many years. However, I believe they have changed some of their suppliers/parts for it over the years, because I’m noticing an issue with the newer sets that I’ve NEVER had with older sets.
It seems the mouse wheel functionality is unreliable due to very cheaply made parts. I’m not sure if it’s the wheel or the “encoder” (the part the wheel connects to that’s soldered to the circuit board).
So I’m on Ali Express looking for a replacement wheel (I’m also getting replacement encoders just in case, that was easy to find). But finding a “matching” wheel has not been so easy. I do have calipers and could take one of the wheels out to measure it and go from there, but I was hoping someone here might know how to ascertain the model name/number of the mouse included in this set. I tried searching AliExpress for MK270 mouse wheel, but that’s not generating very good results.
Any advice on this is greatly appreciated. <3
It appears to be the Logitech M185 Logitech M185 Compact Wireless Mouse - Designed for Laptops
