My current mouse is a Logitech M570 wireless blue marble mouse.
I am looking to replace it with a gaming mouse same button configuration left, right, scroll wheel, forward and back buttons.
Would like to stay in the same price range 40 to 60 Canadian dollars
I would get a new M570 but the switches die to fast this is the second mouse in 3 years and my current mouse is slowly going.
If the switches die on this mouse I am going to take out the switches and see if I can put new ones in. And if that fails then I will need to find a proper gaming mouse
I have use Logitech Mable mice for 20 plus years.
Looking for a mouse that does not need a lot of room to get the job done I am using my arm rest of my living room chair as a mouse pad has 6 x 6 inches of room.
Going to a mouse that moves and not the marble will be interesting.
Mouse has to be wireless. I play fps games skyrim armored warfair that sort of games
I see on gaming mice dpi switches an explanation on what changing the dpi will do would be nice. Yes i could look it up but I think the info from this forum would be better.
When i use a mouse that moves I grip with thumb and pinkie finger.
I look online and all the different sensors and dpi i have no idea what is best.
The sensor has to work on any surface.
The mouse you suggest has to have been working for you over two years less then that and it will not be a good replacement. And no Logitech mice having these mice fail so soon with the cost of $80 canadian with tax gets to be a bother. Looking for solid construction.
I hope this is enough info for some good suggestions.
Thanks to everyone.
Have a day
Buy the Tek mouse
/end_thread
The Tek mouse would be great one problem it is not wireless.
Thanks for the suggestion.
