Logitech g930 quirks
So I got a pair of Logitech g930 as a gift. So I have had them about 2 months there quite decent for sound & wireless is nice.
The thing is if I want to use them I have to go into audio management and disable my speaker then enable my headset & vise verse if I want to use my speakers.
Its there a third party patch that can fix this problem? Anyone have any solutions?
Well it's really not a quirk, it's just that you are using two different sound sources as opposed to plugging in speakers and a headset to the same one.   However there is this cool little program that allows you to hot key each of them: SoundSwitch
trust me, there's alot more quirks you will find. they can be... touchy with some things.
Thanks MrFSDude, I will have check out SoundSwitch save me some time on making my own hot keys, perhaps.
Yes Commissar I did get to close to the microwave too, lol. But if you have anymore experiences besides common scene maybe I can avoid the other "touch things".
No prob bud.  Been using it myself for awhile as I have a USB headset and a separate analog 2.1 Stereo speaker connected to the onboard sound.  It's a really small "indie" program (more of a script than anything else) where you will kind of have to figure it out yourself but it's beyond easy and it does work
