Logitech G15 2007 or Razer Lycosa?
Wuts a better deal to get.
They are similary priced here in Estonia and they both suit for me but which one is better?
G15 HANDS DOWN
Well... G15 2007 I don't like... I like the G15 with blue lights and the flip screen... that's one seemed better.
i like the newer one more and the old ones are sold out here.
g15 2007 by far i dont like the lycosa
Im getting a Lycosa soon as I dont like the look of the G15 2007 and I dont like the orange led's
i haven't used the lycosa, but it looks damn sexy.
i'm using the g11 (first gen g15 w/o screen) and it's wonderful :3
The Razer Lycosa is cool looking you can setup Macros on any key on the keyboard so it is smaller and has anti-ghosting technology but if you like the G15 what for the G18 which has a lager colour screen.
I got Saitek Cyborg on wednesday. VERY comfortable to use, but I dont like the configuration, at start.. I know how to use it now tho.
And as 3dmd said about the macro keys, they are too far away from the WASD keys, so it kinda ruins it.
As for setting macros.. I have no idea how to do it.
do you like more laptopish keys or more normal keys?
if its yes to the first get the lycosa
if the second get the g15
well i have typed a message on laptop but now game on them so i dunno about it.
now=not*
Fix! :P
g15 has more functions than the lycosa, not sure if that matters to you. the lycosa has rubber grip to it tho
Yeh, i think i will go with the G15 ;)
