Just noticed a little check box:
And guess what:
Really neat. Just in case you did not know.
Logitech's software has had support for Afterburner for awhile now. I used to keep all the temps and fan rpm's on the G13 display with a small FPS counter on the monitor. I switched to the Orbweaver a couple of years ago though because I like the feel of the mechanical keys and the d-pad. Logitech's software is still better than Razer's in my opinion though.
