Hello,
coming from K70-rgb cherry mx brown (orig. version, before facelift), I recently purchase MX Mechanical Mini - tactile for 120€.
While I always found my k70rgb - cherry mx brown very light - I feel like I caress keys instead of pushing them down - otherwise I bottom it out and can hear very distinctive plastic(keycap) bumping metal body of keyboard. The sound of these switches is quite sharp even if not bottoming out.
It is even ligther then k70rgb - cherry mx brown - v2 (not the oldest, not the latest pro revision), which my brother bought.
There two sets of switches don’t seem even comparable. Browns in V2 have much more noticable “tactile” feedback, are harder to press (greater actuation force) and I don’t bottom it out that much.
Anyway, I wanted to try TKL/70% version to reduce my back pain (right arm stretched far right, if my B-key is set to middle of the screen) so I went with MX Mechanical Mini from logitech during latest discount on amazon.
Now these are different story. I went with tactile version - which should be comparable to cherrymx browns.
I find the keys quite stiff - comparing to both mx browns boards I have at home. I have to put more force (to extend that I realize it) into typing, my left ring finger started to hurt after couple days using it. The sound is much nicer (I find mx browns harsh and annoying now). I also find the K70 quiet “deep” comparing to low-profile loti now.
Also I find the mx mechanical keys too crammed, although the board is exactly same width as my qwerty part of k70. I don’t like arrows inside the board and home/end button in that arrangement. At the the same time I can already feel my right arm extending too much after getting used to 70% layout over couple of days. TKL might be an answer.
TLDR: Has anyone tried and can comment on MX mechanical? Did I get spoiled by cherrymx browns, or are they not how are supposed to be? Are the logitech tactile too hard, or is it just me? Is the mx mechanical how it is supposed to be, and mxbrowns wrong?
Would you keep it or return, while I can?
