Logan's Skyrim Mods .zip
Hey guys! Has anyone been kind enough to possibly upload a complete .zip of Logan's Skyrim mods or something? That'd be amazing. I'm new to modding, and I just cannot get things to work no matter what I do.
Even if someone were to grab all the mods he uses, wrapped them up and uploaded, which shouldn't be done in my opinion without the mod authors' approval, that won't help you with crashing and incompatibilities. This is what I do, and would recommend:
Make a folder, title it "Skyrim modding backup", in that folder make several other folders such as "GUI", "Visuals and lighting", etc. Basically just separating the mods into categories. Start downloading the mods you want, but while you're doing that, open a document and start listing the mods you're downloading, as well as any instructions provided by the mod author.
After all that is done, install SKSE, Mod Organizer(or NMM), and LOOT(Replacing BOSS) and start installing mods, one at a time. Run LOOT after every 10 or so mods, and open Skyrim through SKSE to ensure everything is working okay(I would install "Alt. Start" early so you can make a new game to test things fast). LOOT is fairly good at organizing everything for you, and it will let you know of any errors.
Check Gopher's channel as well, he has a more thorough explanation.
I'm not sure its possible to package Skyrim mods in that way. Could be wrong, but, because many mods must be configured by hand or by a mod manager its hard to package them in a way that they actually work. I would however really like to see a list of the mods Logan uses. That way you can install what he has or use it as a guideline for which mods to get. If you are new and don't know whats going on STEP is about the best guide/mod list there is. It will help to walk you through the basics and even some advanced settings.
http://wiki.step-project.com/STEP:2.2.9
Appreciate the info guys! I think I installed them in the wrong order, or so I am told, because I just started installign them all at the same time. And Tinman, he has a video on the ones he uses. That's where I got them all from.
