Logan's Skyrim Mods / general mod recommendations
Hey all,
Does Logan have a collection that he is using (Skyrim Mods)? I figured this question has been asked already so I apologize if it has been I just didn't see it in my search of the gaming forum.
Just looking to enhance my gameplay, right now I am using (from the steam workshop)
Towns and villages enhanced collection
Graphical essentials collection
Sounds of Skyrim collection.
totaling about 55~ mods right now. Running 2560x1440p 45-60+ fps. I think my system can handle a little more although I'm not sure what else to add.
Any recommendations?
https://teksyndicate.com/videos/logans-skyrim-mod-list-and-enb-settings
Have you tried installing an ENB? I recently (literally 10 minutes ago) installed RealVision ENB. It's pretty neat. I still need to tweak some things though. ENBoost is a welcome addition as well. My system RAM usage was near the 3.1 GB limit. After installing ENBoost and RealVision, it has now dropped to 700-900 MB.
Also, check out Gopher on YouTube. He has some great advice on modding Skyrim.
TYVM :)
I will check out all the things!
The first step is to not use the Workshop. Use Nexus.
Then get NMM, Wrye Bash, BOSS, ReProccer, and if you're the adventurous type, TES5Edit.
From there, it's all about finding mods you like and putting them all together. I highly recommend focusing on getting actual content and game improvements over purely graphical stuff.
Also be sure to check out Skyrim GEMS, and always read up on mods that have heavy impacts on the game, as they will often require compatibility patches for other mods, or simply cause too many problems to be worth using.
Oh, and use a good process for installation and stability testing. What I do is activate 3 mods at a time, starting with ones that alter large amounts of the game, like Skyrim Redone, and fly around the world with a new character (use a clean save outside of the first cave for your sanity) with tgm, tcl, and speedmult at 1500. If you can do that for 5 minutes, you're good.
With this method and logic, I've accumulated 190+ mods that work in perfect harmony. The only crashes I get are from rouge scripts in the vanilla game. Which is hilarious.
It also took me a solid week, so be warned.
Thanks Ug,
I was using the workshop and have since ditched since someone else recommended I check out Gopher on YouTube.
:) heh..... Yeah i had about 50 or so mods and then bricked my game because I installed too many at a time and couldn't fix it. I think I've learned my lesson. I am sitting on about 50-60 mods right now (mostly graphic overhauls and armor reskins... water graphics... etc..) Not much added content yet. I certainly will start looking for more content soon.
I will say that convenient horses and Sky UI are just amazing. The original bag system was terrible on pc, worked for console but yeah, you know what I'm saying.
Thanks for your input, I appreciate it!
