Hello everyone. My first post and my first full PC build. I was watching Logans video the other day as well as a few others on setting up initial Windows install and SSD/HDD boot sequence. But i have a couple questions I'd be greatful to get a response on.
First. I will be installing a Maximus Hero MB and need to know if i have to update the. BIOs before the Windows 7 install or after ? Should I use the Flash Update option that doesnt require a boot up at all ?
Second. Im going to be running HD 7970 DirectCU2 in crossfire which is why i bought the Hero. I needed the spacing between Pci ports for these two cards. Also this is my first time OC as well and their software looked really easy to use. Did i make a good board decision or should i opt for something else ? It'll be in stock next week.
Ive installed individual components over many years and updated drivers before, but this is my first time working in the BIOs and dont want to screw up the order in which things need to be performed. It will be a clean install. Im looking forward to putting everything together ( bought parts as they went on sale) and getting into gaming. For me to get everything put together at a shop will run me almost $200 and about 2-4 days depending on how busy they are. Im tempted to do it myself and learn as I go or should i pay to have it professionally done ?
My components are;
Storm Stryker Case
Maximus Hero MB
i7 4770k CPU
H100i water cooler
Corsair Enthusiast TX850m PSU
Asus HD 7970 DirectCU2 in Crossfire
Kingston HyperX 120GB SSD
G.Skill Ripjaw 8GB 1600 Ram
Windows 7 Home Prem. 64 Bit
Logan, i loved your videos from years ago and lost track of you. Great to find you again with your own channel and company. Keep up the good work guys and i look forward to hearing your advice as I attempt my first build.
Thank You.
