Logan & Wendell
hi i'm working on my own pc build about 1000 dollar system and i was just wondering (to cut the price) if the AMD FX-6300 six core processer black edition works with the asrock 990 fx profesional amd 990 fx & sb950 atx ddr3 800 amd - am3+ motherboard.
this goes in build a PC since just about anyone can answer it for you, I'll post my build for you in a minute
thx
if you want it cheaper and you don't want to do overclocking I can make it cheaper
be sure to add to cart, log in, set for free shipping, and add promo codes to see actual price
http://pcpartpicker.com/user/Killerfrenzy96/saved/25ze
All parts from Newegg.
