Hi Logan I was wondering if you could help me out with my dilemma with my current PC system.
- Power Supply Unit-800w Tagan Fully Modular PSU,
- Motherboard-AsRock P55 Pro/USB3,
- GPU-XFX AMD HD Radeon 5870/Arctic GPU cooler,
- Ram-2X4GB DDR3 GEIL 1866 Memory,
- CPU-Intel i3 530 running at 4.00Ghz (stable),
- CPUCooler-Tranquillo Rev 2,
- HD'S-(sata)Samsung 750GB/500GB.
I know I need to replace one of my hard drives as its no longer marking bad sectors on the hard drive.
So my only option left is too every so often do a low level format.
Aside from this I use my PC for pretty much everything you could think of, more or less bar CAD work.
Video editing, sound editing, graphics, 3d modelling, creating game mods, website design&coding, general coding, writing literature, reviews, etc.
I know with all the textures I handle on a regular basis, trying to edit them all at once depending on ram being specified to be used. I will need a bigger ram upgrade in the future.
You may have noticed I'm running a 2x4GB DDR3 setup, this is down to a faulty ram module which shot my fourth ram slot. Luckily for me this wasn't fatal to my motherboard.
In terms of cooling and my housing for my PC, I use an Antec nine hundred v1 case.
Not the best case in the world but with the right tweaks does just fine.
So now you know the details, I was wondering if you could please shed some insight on the best upgrade path for my PC system.
I don't tend to use big monitors, I'm currently using a 19 inch tft widescreen monitor.
Resolution is 1140x900 also I was easily put off by the premiums that ensued since the 1155 socket from Intel for unlocked CPU's. And as I've a strong tendancy too overclock like crazy, the price point put me off upgrading to 1155 so far.
I've been waiting for prices to drop and where I don't mind being behind in terms of the CPU line in terms of the sockets from Intel, I'm seeking to get the best performance and usage for my needs.
I'm not your average user by any stretch of the imagination, probably far too picky in some people's minds.
