Logan and the gang anyone pls help
I have a few questions. Looking to build new machine only newbie.
I’m in Australia looking at the Pc build vids take the AMD $1200 build as an example same thing in Oz is just over 2K even with exchange rate it should only be $1300 give or take few $$
Ram 1833 and over are dear as posion cpu, MB, Graphics card,SSD and power supply not much better hang on what's left DVD like you need that :(
So my questions are.
1 Can I buy the parts in/ from the US if so Where ?
2 Australia runs on 240power as apposed to 220 in US I think, will that affect the system from running if so what parts ( I’m thinking MB maybe )
3 If can’t run system as above question will any parts be able to run.
 If it can be done it’s worth exploring even with the freight still miles ahead of what it will cost here.
Things like case maybe not worth the effort but smaller things must be a better way.
Appreciate any feedback.
No idea where you were going with that. Or what it was above that. Anyway, I should start off by stating this should be in "build a PC" forum, or possibly "other hardware." I believe the inbox.exe section are for question that only Logan (and team) can answer, where general questions such as this should be posted in their respective forums. However, I'm no mod, and not 100% on the rules, but I'm pretty sure they are somewhere along those lines.
Now, onto the meat and potatoes:
Any retailer who ships outside of the US, or, more specifically, ships to Australia. I'd just buy from a retailer in Australia unless there is an absurdly overpriced component that you know for a fact you can get significantly reduced pricing for by shopping elsewhere; the main reason being that international shipping ain't cheap.
The US runs on 120v AC power. The only component this affects is the power supply. All components use DC power, and the main purpose of the power supply is to take that AC power and convert it to DC for the components. Most power supplies support both 120v and 240v (though efficiency may vary between those two), so this shouldn't be a big problem, but double check the specs. Just make sure you have the appropriate power cable. Again, the best way to avoid any sort of compatibility issue is to buy locally (and by local, i mean in your country, not necessarily in your city.)
I believe question 3 was already answered.
Have you tried looking at PCCaseGear? I think they have affordable parts (though selection is bit limited), but I'm not a resident of Australia, so I wouldn't really know. I do, however, use the site to help other Australians with their builds.
https://www.pccasegear.com/
Thank you Jerm for the reply.
I don't know what that jibberish at the start of the post is :( I never put it there, only newbie so may have done something wrong :(
I wasn't sure as to where to put this post I thought Logan and co would have some ideas as to sourcing of parts. The one link you provided for the OZ site is quite good thank you.
 I'll look to re- post this ( or version of it ) in different thread.
Thx again for your reply and advice.
Cheers
