Hello all! Curious if anyone with a NextCloud deployment on TrueNAS Scale has been able to use the account integration in Gnome. The process always fails when I tell it to ignore that the cert is self signed and just use it. Then tried adding the truenas_default.crt to my Fedora install after converting it to a .pem.
I also just use TailScale so I don’t have to worry about reverse proxy or anything. I keep things simple cause that’s all I can handle.
Still no luck so far and also in no rush.
Thank you for your time!
