I've decided to take another stab at using Linux. I'm attempting to install Arch on my Acer laptop (Aspire V3-772G-9653) by dual-booting with windows 8.1. I've used the universal USB creator to create a bootable USB, but whenever I boot off of it, it says it failed to start the loader, which should be called "loader.efi"
I can select OK, go to a "hash tool main menu" where it wants me to enroll a hash, which I have absolutely no idea what it's referring to.
I looked on the installation guide on the arch wiki, and I'm thinking that maybe I need to disable secure boot and fast boot? At any rate, I have no idea what to do, and one of my friends who uses arch on a regular basis has no idea what the problem is.
Looking at the instructions from that link, I'm able to load the loader.efi in that manner. but I can't find vmlinux-efi. Where should it be? Do I have a broken .iso?
Looks under the secure boot section. You really do need to have the wiki open when you do an arch install. You save time and headaches by going with manjaro it still is arch.
I like learning Linux from a top down approach, Use an easy but powerful distro and then work your way into the more complex parts. Sabayon is based gentoo and and also easy to use.
I've gotten to the point where it talks about exiting chroot and rebooting the computer, and everything up to that point has seemed to work fine. I disabled fast and secure boot, and it STILL does not show the grub bootloader menu, and always boots to windows 8.1.
Yes, I've done everything up to that point in the guide. I exit chroot, unmount everything, and reboot. It brings me to what I assume is the gummiboot boot menu, there's options for Arch, Windows, UEFI firmware, and one other thing.
If I select the windows bootloader, it boots into windows just fine. But when I select Arch, it gives me that error.
is /boot on a different partition? if so is it mounted? I'm assuming yes to the first question since you are using UEFI, make sure that you are mounting your efi partition to /boot/EFI as mentioned int he guide
It is properly mounted, yes. For the config file for gummiboot, the partition I want to use in the last line is the root drive, not the boot drive, right?
Well, I just decided to restart from scratch- I got rid of all of the arch-related partitions except the boot partition since that contained the windows EFI partition.
I'm able to boot arch just fine now with gummiboot, but I'm not getting the menu to select other OS's; my laptop immediately boots into arch.
Youll either have to do this in CLI, or open your file browser as sudo. You'll probably have to mount it first.
And make sure it shows a windows boot option in the conf file. If so, and the timer is set to 0, then up it. If there is no windows option, then I'll have to figure that one out.
