So I'm thinking about building a replacement for my blu-ray, smart box player that pretty much controls the living room but is doing a terrible job of it. Most of the time the kids end up moving into the computer room and start using my PC to watch programs or play on games.
So I figure I could do a better job by building a mini pc that possibly runs off android (maybe not) in order to do things like stream movies, play dvd's and blu-rays, browse the web and maybe do a bit of light gaming.
Has anyone got any advice for the smallest possible builds that would have mid range specs? I built my first pc last year and this is my next project, I just dont know where to start, any advice on specific components would be great.
Seithe
Have you thought about an Intel NUC? Or maybe just a chrome cast if you already have an android phone.
There's the Alienware Alpha...
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=9182719&SRCCODE=WEBGOOPA&scid=scplp1975679&kpid=9182719&gclid=Cj0KEQiAiamlBRCgj83PiYm6--gBEiQArnojD8mYezb4Ye7YUDSrBf1ZDPhGv3DFY8-ay1wj2L_aFwYaAs1V8P8HAQ&gclsrc=aw.ds'
And there's this for the same price that doubles most of it's specs...
http://pcpartpicker.com/p/zPyGt6
You didn't really mention a budget, but this should settle all your needs.
Small, powerful build... not the cheapest.
http://pcpartpicker.com/p/FpVM23
highlights:
- Very small (doesn't get much smaller.
- Silent.. like REALLY silent, even under load (Excellent for movies and quiet games)
- i5 processor for very good speed, multi-tasking, and gaming performance
- 8GB of 1600mhz ram (ultra low voltage @1.25v)
- All power saver components for 24/7 operation (if you wanted)
- Dust protection (I would add a magnetic dust filter to the top power supply vent for 99% dust proofing)
- SSD for speedy performance and boot times. No disk fragmentation, and less slow down over time.
- The PSU is gold efficiency rating and has lots of power for adding almost any graphics card you could want for gaming needs.
**This has integrated graphics, but if you need more for gaming or etc, almost any discrete card you want can fit in this case.
**I only included a single 128GB SSD because I figured you would stream most content online or from another PC on the network. A full sized HDD can be added to the build for additional storage.
Here is a second one that is much more affordable but a bit bigger
http://pcpartpicker.com/p/LZvpWZ - This is very similar to above.
Ultra cheap (but still good quality), and pretty much streaming only. Not much future expandability.
http://pcpartpicker.com/p/V7gkRB
Highlights:
- Cheap
- Quality parts
- Very small
- Still decently quiet
- i3 devils canyon processor
- This will handle just about any casual game and any video watching you can throw at it.
**You can still add a DVD or blueray drive to this if you want.
***This isn't really recommended for higher end graphical games by any means without a decent power supply and graphics card.
********All builds have built in wifi as well as 2 Ethernet ports.
