Living life on brass thanks to DIY
I got two very old brass fire extinguishers. But as you can see from my limited amount of potato quality photos they are tarnished and dirty.
I looked up a diy way to remove the tarnish. And it appears that ketchup can remove the tarnishing.
So seeing as my family keeps an abundant stock of ketchup, I decided to give it a try.
Here are some before pics of the two fire extinguishers
I will start on the underside of the top.
Before:
During:
As you can see. Not much happened. So I will switch over to a watered down vinegar salt solution.
The salt and vinegar solution seems to be working:
But it’s taking forever. But for the record, I am using a half cup of white vinegar mixed in with half a cup of warm water and I just stirred in a tablespoon of ionized salt.
Switched over to a steel wool pad, and am just gently rubbing on the solution. And this is working faster and better then just using the rag:
random idea
electric toothbrush :man_shrugging:t2:
Brooooo. Why didn’t I think of that. I’ll see if I have one on hand.
Right now I’m going to hold off on this for a few days. lol. I feel really defeated. I thought this was going to be like a 2 minute job. I thought the tarnish would have just melted away.
Realistically I do have some Tarn-x. But it says that you can’t use it on brass. That’s why I went with a diy route. But the Tarn-x just melted the tarnish away the last time I used it… But I used it on an approved metal. I don’t know the consequences of using Tarn-x on brass.
Huh.
According to this guy, salt can turn the color of brass a salmon color:
Nopers, years back the american rifleman posted an article in their magazine. it told the way to clean the brass was cider vinegar but their post said to add a couple of tablespoons of salt DON’T DO IT It will turn your brass a salmon color. Just stir the brass around then wash it in clear water to stop the acedic action. then let it dry. luck hotdog
Good thing, I tested this idea on the underside of the lid. And even then, I just did the rim and that little pocket area in the lid.
