I've got a small problem with a print of mine, I decided to ditch all my slicer profiles and start fresh becouse i did so many things that i didn't even know what anymore. So i-am re calibrating. However now i run into the problem that the first layers are excelent but (i guess bridges) arent as great. It does not fil nor always connect. What should i change? i use repetier with Slic3r There's also a weird straight line artifact but that's not really bothering me.
Split the object in two, print it on the side, then glue the two halves together, or just use manifold objects printed right side up so that there are no bridges but those on the standard rafters.
