Litecoin mining setups!
I have a 5770 and two 6850's. Each get around 200kh/s. What are you guys mining with?
i am now starting gigacoin teracoin and petacoin
I am doing litecoin on an A10-5800k.
I need a new GPU.
I've not tried Litecoin yet, is it worth doing with a CPU?  I've got an i5-3570k and its on all the time.  I also have a PC with a GTX 650Ti that I could use, is this similar to Bitcoin where AMD cards are favoured?
Looking at this hardware comparison, it appears that AMD GPUs (and CPUs) are indeed favourable.
I'm using a single Radeon 6850 @ stock clocks and getting 240 khash/s.
I use a single 6870. I mine litecoins all night until i get home from school. Then i turn on bitcoin miner and mine in tek syn mining pool.
Check this out for NVIDIA GPUs, you'll get speeds with that that are worth mining on:
https://bitcointalk.org/index.php?topic=167229.0
IF YOU USE THIS MAKE SURE to READ the readme, and put -C 0 in your launch options (that option is broken right now, hopefully he will release an update soon so we can turn it on as it increases performance a lot)... if you need more help I can write up a mini guide and post it on here :)
also run this for cpu, if you OC to 4.5 ghz you should be at 50 kh/s on CPU, not sure about GPU but I'd estimate ~100ish
https://bitcointalk.org/index.php?topic=55038.0
I started yesterday with my 3570k and 7770. I average about 120-130khash/s while still being able to use my computer for normal use.
Using a Gigabyte Windforce 7970, with stock clocks: Core clock @ 1100, Mem clock @ 1500. I get about 530-550 Kh/s with reaper.
heya,
I'm on 6950 (the 1GB single bios version) @ stock with up to 300 kh + phenom ii 940 be stock around 15 kh (on 3 cores)
Currently using a Sapphire 6950 2GB @900Mhz core and @1300Mhz memory, average around 390-430KH/s using reaper with worksize at 256, aggression at 20 and gpu_thread_concurrency set to 12288.
200khash/s with gtx 670 + i5 2500k
7950 @ 1125 averaging about 620 Khash/s , Cant get my CPU miner running though because minerd hates me.
Just started like 5 hours ago after catching up on an episode of The Tek and diving into the forums, so I am just using my own personal setup to do this at the moment.
Which is my ASUS GTX 660ti (pulling around 130-140 KH/s) and my Intel i7-3770k 3.5ghz (neither are overclocked currently, dunno if it would make all that big of a difference) and with Minerd that puls around 50 KH/s on average. So 200 KH/s is what I am neting, not bad for just using what I have.
I have a REALLY OLD AMD setup, and a GTX Superclocked 570 that isn't being used, I think I am going to turn that into a dedicated mining machine so I can still game, record and stream on my rig, besides the 570 nets about the same Khash/s as my current card.
I can't afford to get an AMD GFX currently, wish I could cause I wanna go hardcore at this!
how is a 660ti pulling only 130 kh when my 560 pulls 130kh... lol what miner are you running for your gpu
500 series is much better at mining than 600
In my main pc I mine with my GTX 670(1360 core) when its on, it gets me 150-175 Khash/s. Then in my home server I have a 7870 and a 6770 the 7870 only mines during the day due to noise and it gets me about 330Khash/s while the 6770 mines 24/7 and gets me about 200-210Khash/s.
So you can have different types of cards, but not run SLI/Crossfire and you can still use them both to mine? Damn, I gotta do that. Lol AMD > Nvidia when it comes to mining, that is for sure.
yep and yep
