Hi there I was wondering if anyone could help me understand what is going on in reaper because at the moment it is reading GPU 2.068GH/s, shares: 0|0, stale 0%, `0kH/s, 835s
and it is stuck with the one line.
I am solo mining and I'm only running a laptop with a 4570m in it so I doubt that 2GH/s is accurate.
So my question is can anyone help me fix my config
termhn
April 15, 2013, 2:52pm
#2
screenshot your cmd prompt
http://tinypic.com/r/1zyemg2/6
termhn
April 15, 2013, 3:12pm
#4
hmmmHmmm... At the top when it first starts does it say "now mining litecoin" or "now mining litecoin"
now mining litecoin and I have removed both protocol bitcoin and protocol solidcoin from reaper.conf
termhn
April 15, 2013, 7:54pm
#6
Not really sure... post your reaper configs on pastebin or something
reaper config is here: http://pastebin.com/gYEy2KGB
and litecoin config file from the reaper folder is here: http://pastebin.com/Tnj4c7Lu
termhn
April 16, 2013, 2:44pm
#8
You need to change your host, port, username, password in litecoin conf
host 127.0.0.1 <- change to server
port 9332 <- change to server port
user username <- change to worker name
pass password <- change to worker password
protocol litecoin
worksize 256
aggression 18
threads_per_gpu 2
sharethreads 18
lookup_gap 2
gpu_thread_concurrency 6144
I plan on solo mining so what do I change the username and password to ? and do I need to setup an account with a pool even if I'm solo mining ?
termhn
April 16, 2013, 6:33pm
#10
No you don't need an account on a pool. Look up a tutorial on solo mining
okay then thanks for your help
