Liquid Cooling Recommendations For a Military Themed Build?
Hi Everyone,
I am just finishing my military themed build in a Corsair C70 Vengeance case with a custom "bullet-hole" acrylic window with an ASUS Z77 motherboard. I am looking to do my first custom water cooling loop in this case and would like some advice/ideas on what particular parts you guys think would look good in it. I have done some shopping around and have a few neat looking reservoirs and blocks in mind but would like to hear the expert's opinion!
Ideally I would like advice on any neat ideas for specific res's or blocks and where I should put them. I also think I will include my GTX 670 in the loop as I would like to overclock it a lot more than the factory fans will allow.
Here's a couple pics to show what we're dealing with (the H100i will soon be my brother's and this loop will replace it, also the case lights are white, they just look blue in the photo):
Thanks a lot!
Myles
XS-PC makes some good stuff. http://www.xs-pc.com/
Also bitspower: http://www.bitspower.com/html/product/product01.aspx
