I have a Corsair H50 cooler, I was wondering if theres any downside or bad effects from shutting down the computer. Is it better to put it to sleep? What would be the best thing to put it into when Im not around. Thanks!!
Honestly, you should be fine with treating your H50 like any other cooler. Being that it's a completely sealed and closed loop system you shouldn't have any issues with it. I have a completely custom water cooling system and usually leave it on for a few days at a time. I've never had a single issue with it leaking if that's what you're worried about.
i have 2 H50's on my gpus, been up for about 4 months now no problems.
