Liquid Cooled Console Killer ($450) - 2014
Logans recent video on "Kill Your Console: Build a $400 Gaming PC", was interesting. However many items I had looked at listed, were prices higher than preferred. So it got me thinking, what would be even cheaper and better for everyone. Well, this list however is $50 more, specs for the videocard benchmark in some cases 240%-400% more, the memory is $15 cheaper and I found a liquid CPU cooler for $30. Some may not like rebates, but for those who are ok with them, this is your list.
  • GPU(cheaper/better) - SAPPHIRE DUAL-X 6970 2GB - $89.99 / $10.00 Rebate
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16814202113
  2. Benchmark - https://docs.google.com/spreadsheets/d/1NZj6U8A1QIvGj9KYZFG-61On3wGnoPyJdNsNbrCGUMc/
  • CPU - AMD 760K Quad-Core 3.8GHz - $77.99
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16819113348
  • CPU Cooler(cheaper/better) - Enermax Liqmax 120S - $69.99 / $30 Rebate
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16835214055
  • HDD - WD Blue 320GB - $24.75
  1. http://www.amazon.com/dp/B000Q85WOK/
  • MOBO(cheaper/better) - ASRock FM2A78M-HD+ / 6Gb/s / USB 3.0 / DDR3 1866 / 5.1 / Dozens of features - $52.99
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16813157482
  • CASE - COUGAR MX300 - $39.99
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119274
  • PSU - COOLMAX NW-650B 650W - $49.99 / $20 Rebate
  1. http://www.newegg.com/Product/Product.aspx?Item=N82E16817159082
  • MEMORY
  1. G.SKILL Ripjaws 4GB (2 x 2GB) DDR3 1600mhz - $42.99
  2. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
  1. (cheaper/better) Team Dark Series 8GB (2 x 4GB) DDR3 1600mhz - $60.99
  2. http://www.newegg.com/Product/Product.aspx?Item=N82E16820313342
crying
tears of joy?
Amazing track record.
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=379
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story4&reid=106
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=68
