I have to get a web cam for some telecommute / remote-conference stuff. What is the best option(s) for Ubuntu? It’s my understanding that pretty much any USB web cam will work.
And from what I have heard over the years most will work, but I haven’t bought one since like 2010 so I guess I see what other have to say since mine can push a whole 720P at 23-29FPS so I need to upgrade to…
Basically any webcam will work. I got one from amazon with a basic driver and worked right out of the box.
My Logitech C922 works fine, and from a quick skim it looks like most of the Logi ones will. I use it for my classes (Blackboard Collaborate or Zoom, depending on what the teacher likes) and it’s waaaaay more clear than people just using their laptop webcams. Good lighting helps as well. I’m not sure about Microsoft ones (haven’t used one in several years).
There are a few different models with a significant discount on Amazon right now.
I use this as well.
I have a Logitech C615 here.
Drivers included by default in Linux, so works flawlessly with every distro. Just plug it in and fire up whatever app you’re going to use.
I just bought a Logitech 920.
Was basically plug and play. There was no Logitech software for it ( that I was able to find ). But GUVCview mostly works with it.
As well as v4l2ucp ( with exceptions to a few features ).
