Okay so I understand that this question does not fully fit the subject area but programming is no one for this.
A friend wants to learn python and possibly other languages but cannot decide on the OS to pick.
Gaming is a secondary thing for downtime, although native support is better, although I have seen that steam seems to be getting a3 titles on Linux now :)
So which is better? The system will be hackintosh if osx and well a Linux PC is its linux.
My personal recommendation is Linux but I am no programmer or OS pro.
Linux will have support for a broader range of hardware. OS X has Xcode which is a great IDE but it isn't aimed at Python. If your friend specifically wanted to learn Objective-C, then OS X would hands down be my pick. Otherwise, Linux is probably the better choice.
Personally, I have a tri boot of mavericks, arch Linux, and windoze 7. I must say that I boot into OSX the most because the interface simply looks beautiful. Also, I have pages and I would take that any day over google docs for schoolwork. However, that being said, Linux has been better for both gaming and coding in my experience. Mac OS X has some weird mouse acceleration thing that makes playing TF2/ L4D2 impossible. You can pretty much customize everything in Linux and works with a lot more hardware. Another thing is that I have a SLI setup and mac os x doesn't support that. I use Netbeans for coding, but there are a ton of other good IDEs that support both Mac and Linux.
TL;DR - By your description, I would tell you to get Linux, but Mac OS X is just so damn pretty :S
I agree OSX looks beautiful but I think, the fact that metro has just been released on linux also, the fact the requirements are so low on it also would push him towards Linux for gaming, I would say for him to get Arch but chances are he would struggle installing it and to be fair Manjaro is good but it does not beat stock arch imo, the feeling of finishing it for the first time also :)
So the next question, Arch v Ubuntu? I know the linux lot here love arch and I cant blame em but think of it from a basic user.
Also forgot to post Freq, Its mainly Python, Bash etc scripting stuff
Personally I use Linux Mint for linux programming. With a few adjustments its close to on parr with OSX in beauty as well. The recent updates really make it amazing and responsive with all of the right drivers.
I geek way more out over how pretty my FreeBSD desktop is versus OS X, but then again I put a lot of time into customizations. There's not a lot you can do to tweak the appearance on a Mac (aside from XQuartz...).
As for a distro, I think Debian based distros are the easiest to get started with. I like Arch for bleeding edge and all that, but when I just want to get an install up without going through a whole tedious process, I generally turn to Debian. But I also tend to prefer minimal installs, without any desktop frills or stuff like that. For a beginner, I'd recommend they look at Mint, Ubuntu, Fedora, and maybe Manjaro (but that's Arch based and it is no secret Arch is not afraid of breaking things), then let them decide which they would like to try out (or better yet try them all on Live CDs). You can't really go wrong.
I personally use both osx and archbang (and windows too) but I would say I have the best experience with coding while on archbang (any *nix can really just be on par with it, the distro is just a personal preference)
I would have suggested Ubuntu for him but the fact that Ubuntu is not what it used to be anymore, The reason I left windows for linux was because of the crap MS was doing, and from what I read Ubuntu is going to follow.
Also I though about Openbox at first for him, get used to a minimal DE with the ability to customise it when he wants and how he wants.
Also I was thinking Sublime at start, I have yet to try Vim also, I researched it a little just havent had time recently, remember this person is from Windows only, cant let him go all out command straight away, Although its not super hard to learn.
But the fact Bash/Python are scripting languages he can automate stuff later, something I would love to do :)
Sabayon 14 KDE is pretty. I would recommend Linux over OSX even though I really want a an OSX system myself :( I would also try ZorinOS, but that is Ubuntu based I believe and you may not want that. However, my family is all total computer noobs and after switching all of their PCs from Win7/XP to Zorin they were comfortable with it almost immediately.
I don't have anything to do besides browse forums ;P
Just to clarify, I would like to say that I'm not using mavericks JUST because it looks good. It also has its merits, some of which help a lot with programming. For example, Mac OS X has extremely handy "frameworks" that simplifies compiling a TON. You may or may not be using C/C++, but here's and example:
Mac OS X is also stable, much easier to use, and more supported in terms of application compatibility.... that's if your hardware supports the OS in the first place. Mac OS X has some pretty specific hardware requirements - if you have an AMD CPU, you're going to be in for a rough ride. tonymacx86 is a pretty good community and will be glad to help you out. Regardless, depending on your hardware, you may be forced into Linux (which isn't a bad thing at all). As for Linux distros, any Debian-based distro is aimed more at stability and usability (Debian, Ubuntu, Mint). There's a reason you see a bunch of Debian web servers around and never a Arch Linux server. Steam is also only officially supported on Debian and Ubuntu, but all distros use the same binary format, just different packaging and install directories. Arch Linux is what's called a rolling release, so you pretty much always get the latest versions of software. In arch linux you also get the extremely handy Arch User Repository, which pretty much has pkgbuild scripts for any program you can imagine.
Another thing to take into account when deciding between Arch Linux and Ubuntu is the "future" of the distro. The graphics display server for both is currently the X Window system. However, Ubuntu (and its derivatives i.e. Mint) is probably going to move to Mir in the future whereas pretty much every other distro is going to use Wayland. This may cause some compatibility issues in the future, so that may be something to keep in mind.
TL;DR (again) Mac OS X not only pretty, but other things too. Arch Linux is for living on the edge, Ubuntu is for stability. I would recommend Arch Linux (or its user-friendly derivative, Manjaro)
Well there is Archbang, easy to set up Arch. For whatever reason I couldn't ever get Arch to run on my laptop, even though I followed the wiki exactly. Archbang was a breeze, but I decided I liked Elementary OS Luna more. If you love the look of OS X you should definitely look into that.
I would recommend Linux, but that's just because I've used it for years, and don't really like the inability to customize Apple products. If you do go OS X make sure your hardware is compatible though. You could always dual boot as well. There are definitely more games for OS X, but that will (hopefully) be changing due to Steam OS. As for programming, well I don't know much about that.
He's gone Linux I tried both mavericks and mountain lion and I can't get them to work and am not using iatkos.
I showed him arch in live but i recommended against it for his needs, although its a superb OS its not stable enough, although I run arch and swear by it it has broken a few times.
So yeah Linux deb base it is if he really wants osx theme he can do something about it
Also just to add steam is stable on arch too maybe not as stable as deb but yeah :)
Even if you want to count ctrl they're still on 3 each. But then in Vim you have to press i to start typing again. Not to mention what a pain it is to reach for escape. Should I just remap it to the caps lock key??
