Linux remote desktop
I want to connect Linux remote desktop to Windows, is it possible and how to do this using RDP? What options are there? I’m new at this, so a step-by-step tutorial would really help me! I would be grateful for any help!
Take a look at xrdp
http://xrdp.org/
Yes it’s possible. But to enable remote desktop Kali you need to download and install all the packages required and update the ones you already have to the latest versions. There is a good article on this subject, there are instructions and screenshots: https://www.helpwire.app/blog/remote-access-linux-from-windows/
