Linux RDP clients and CredSSP
Have you guys found a RDP application that works after the CredSSP patch without changing the GPO to not secure settings? Is a client even compatible with RDP 6.0?
Ive tried Krdc and rDesktop, and both dont work. Im on Arch Linux
Thanks
Does Remmina not work?
I’ve not tried CredSSP on Linux yet, I went the OpenSSH route for Windows. But from what I recall Remmina was packed with features and extensions.
It does, after i built it from source.
If you needed to manually patch the server, you’re going to need to manually patch the client.
Remmina is good, but don’t expect it to support advanced features until they’ve been around (and compiled in by default) for a long time.
I don’t see the problem with building a program from source. Especially on Arch.
I just want Krdc to fix it… i really like Krdc…
I like Krdc too, but if you want it fixed, submit a patch or issue?
